1 - 18 of 18 Posts
Im trying to figure out what to use in mine too on a Carb'd 6.0. Would like to stay w/a GM one, someone said to check out a GN or S10 cable. Havent checked it out though-
The non cruise control cable is the best option if you are using a stock pedal , and the throttle body is mounted forward facing. If you've gone carb style intake it will still work , but its a little long.
We reversed out TB/intake elbow so it's facing rearward. Also, we reversed the way the cable works, so the stock cable wouldn't work anymore.
Like ATVracer said, we bought a LS1 style universal mount cable from Lokar, and made our own bracket for it inside the car. We used the stock pedal from there.
Lokar
rod kit from mcamis and fire wall boot
stock cable and pedal...
I took the plastic piece that the cable hooks to from a v6 throttle body
and mounted it to the shaft of my Wilson 95 mm single..
then modified the v6 cable bracket to bolt to the elbow bolts..it works great
and didn't cost me anything to make !
I think ours is actually a ford type throttle cable with a pedal built when the chassis was built
1 - 18 of 18 Posts
