1 - 12 of 12 Posts
i have a b&m pro stick with the 4 speed gate forward pattern i have to put it in 1st and hold the lever in to shift into second then let go of the lever and push the stick into 3rd and i hate it what do you 4l80e guys use for just bangin the gears without all that lever work its tuff enuff to line lock , footbrake, launch , hold on for dear life and drive the car without holdin levers and no i dont want a paddle shifter i like bangin the gears way too much
I have a tci outlaw and I just have to slap it into 2nd and then pull lever for 3rd...basically just find a ratchet shifter that will work with the 4l80 pattern if u don't want to pull any levers to shift
i think thats half the problem......finding a shifter like yours compatible with the 4 speed pattern does tci offer a four speed pattern in outlaw shifter ?
Smoked another CTD
X2 on the B & M pro rachet, i used several, love them, just hit the lever and go-you have to pull a pin for 4 sp trans, and i think rachet twice in/out of park, but no big deal, and make sure the cable is mounted the correct way at the shifter housing, and correct location on the trans lever, bullet proof
Which outlaw did you get? The only one I see compatible with the 4L80 is a $500 shifter!
I have the pro stick for my 700R4 and i just slap it into second and pull the handle to get into third.I'm about to install a 4l80e and thought the shifter and cable would work with no problems.I think the 80e has the same detent as the 700.
1 - 12 of 12 Posts
