I have a performance built 4L80E. Has billet input, direct drum, good stuff etc etc.
Has a Circle D triple disc converter that has been in the car for over a year but this issue started to happen lately.
Has approx 1/4" spacing to the flexplate before bolting up. Looking at the pump gear and converter on the bench you can see where it is riding and is obviously not bottoming out in the pump.
TCI flexplate looks good.
Engine is fresh so thrust bearing is good fwiw.
Pump gear surface looks like it is coming apart and in turn grinding into the pump.
Any ideas on this?
Combo is turbo around 1100whp, no dragstrip action its a roll racer so it sees full boost in top of 2nd, 3rd, 4th with converter locked in 3rd and 4th.
Any ideas on this?
