I have a 4L60 that I believe is centrifugally applying the reverse input drum clutches. The trans was brought to me due to no 2-3 shift at wot. I figured the 2-3 clutches were toast and maybe a pressure leak somewhere. During teardown I found the direct clutches show some heat but definitely not burned up to the point where it would slip that bad. It is an 8 clutch pack build. Further inspection revealed forward clutches to my surprise are totally fried. After that I found the reverse input drum clutches are toasted as well. I originally built this trans over 2 years ago but it hardly ever gets taken to the track. The reverse piston was keyed to the drum with a steel and the piston has a .0625 bleed hole in it. I also cut a groove across the bleed hole on the piston so it would vent even if the steel was seated tight against it. The snap ring is intact also. I suspect the drum is applying with rpm. This car has a 4800 stall and shifts at 7000 rpm. All the shaft sealing rings were replaced by me and they all look new. It has a transgo HD2 shift kit. I cant find any evidence of a cross-leak anywhere.
I feel compelled to drill more bleed in the piston. Do any of you think this would be beneficial or is there something else I could try?
