1 - 19 of 19 Posts
hello i have a 496ci big block chev, going blow throw and single turbo and a mate has a cummins truck turbo, has been rebuilt he was told it was a t18a but the specs he gave me are it has a 130mm compressor wheel with a .81 cover and a 1.70 rear housing, it seams prity large but i dont mind if it will work being an truck turbo they usealy are quite large i supose,
what rpm do you think it will be on boost by,
ANY INFO ABOUT THE TURBO WOULD BE GREAT,
thanks in advance Andrew
i dont really know much about turbo's but the rear housing is huge-
u hear here and their of a 1.32 or 1.50 exhaust but never heard of a 1.70 on a race set-up
thats better left to buses and trucks ----
i could be wrong-
Nick--
Custom Engine Shop
That is a huge turbo should work well a 8000rpm.
yeah to me the 130mm wheel sounds to big to me but i have not seen the turbo, withthe sizes you said you think it will be what would it be like on my engine,
cheers:peeing
Discussion Starter · #8 ·
Custom Engine Shop
From the pic it looks like an 80-90mm
The 1.70 AR is still huge.
Custom Engine Shop
i thought it may be to big a rear, what do you think would be suited for my motor size wise, keeping in mind i would like to stay single
How much hp you need or want?
Custom Engine Shop
Custom Engine Shop
will there be a large amount of back pressure problems do you think with a s475 turbo,
thanks for taking the time to reply ,
Andrew
These have a 1.32 hotside. At only 650 hp I imagine you are not turning it too hard... So it will not be bad.
1 - 19 of 19 Posts
