1 - 3 of 3 Posts
HEY GUYS A COMBO LIKE THIS WHAT KIND OF HORSE POWER YOU THINK IT HAVE 496, RACERITE BRODI,TEAM G INTAKE, 1050 DOMINATOR,685/692 ROLLER LUNATI ,13-5 COMPRESSION.POWER GLIDE TRANS ,5500 MOTOR CONVERTER,411 GEAR 28.10/5 TIRES STOCK SUSPENSION 1979 MALIBU ABOUT 3,300 LBS. WHAT KIND OF NUMBERS ANYONE THINK I SHOULD RUN 1/4 MILE AND HORSE POWER SHLD MAKE.DO YOU THINK NEED MORE GAS OR ENOUGH FOR COMBO R TO MUCH
I have a 496 with just over 11-1, racerite ovals, single plane intake, 1050 4150 from Pro-systems, 714-724 bullet roller, with a th400, 5200 converter, 4.86 gear with a 33" tire, in a 2600 lb. Model A that has ran a quickest of 9.90 at 133 mph with 1.29 60ft. goes thru the traps at 7100RPM The suspension and weight is all wrong in the car, it was never built to be a race car..... it still runs a transverse leaf front and rear and there is zero weight behind the axle.....hope that helps
1 - 3 of 3 Posts
