1 - 12 of 12 Posts
Driver MJM Racing
Just wondering, want a good head for a 496 BBC Im building running NOS lightweight S10 Truck 2250lbs with glide. Run Mostly NA but will be hitting around 350-400 once we get it straight.
Was looking at the Brodix Line of heads just not sure which one. STS BB2 Plus looks good.
Driver MJM Racing
4.31 Bore im using so just want to be sure there wouldnt be any issues.
I would run their bb3xtra 332 if you were getting one of their cnc ported heads. I have done many bb2 plus heads that I have hand ported and have had very good luck with them. That would save you some money. Brodix has a very strong casting so you really can't go wrong with them.
Driver MJM Racing
Discussion Starter #7
Looking for a pair of used any ideas? Also any Piston Dome recomendations for a high compression motor and dont realy want to have to worry to much about Piston to Valve.
I run Dart 335 CNC on mine, with JE 118432 (I think is the number, they are the old design) and have a mile of p/v clearance.
Driver MJM Racing
Discussion Starter #9
Im guessing thats a custom piston......
It is a shelf design for 24 degree stuff. It has been superceded to a new number now 258243. It fit the Dart chamber great.
Driver MJM Racing
Discussion Starter #11
Thanks saw them and was leaning that way in dome for sure for the Compression
I'm building one using a Merlin 320 heads and a 40cc dome srp pistons. Hope I makes good power on a 300 shot.
1 - 12 of 12 Posts
