1 - 6 of 6 Posts
I was wondering if I could use my pistons in my 468 if I were to stroke to a 496 or if a piston with a shorter skirt is used
its pin height thats your issue ,,,your probably using 6.135 rods and will need to go to 6.385 rods with the additional stroke which requires a 1.27 pin height ....your pistons on the longer rod with the additional stroke will be way out of the hole ...just the srtoke difference with your rods if the skirt didnt hit would put you .125 out of the hole
Yeah it only makes since and I appreciate the info. I was trying to cheap out and piece together a rotator without buying slugs.no extra money and I havent tried the spray yet so might as well leave it as it and try the spray and hopefully have fun! Love this board so much it ridiculous!
1 - 6 of 6 Posts
