Curious if run on race gas can you make 1000hp 468 afr heads 8.5 comp 8/71 dual 1050s. how much boost? thinking of a under blower intercooler curious if they mess up flow to cylinder heads any body with experiance with one?
If I remenber B&M some years ago dynoed and tryied alot of things but only got 950 hp,they found that a a W/A intercooler under the blower worth 80 hp.....This engine was used in a T Roadster called Limefire........OLDHEAD
interesting, i got even colder intake temp in my motor (120 at wot) without a chiller but i use e85 for fuel. why not use that fuel instead of a chiller?well i ran mine on C-12 VP at 9% OD,30* timing,.646intake .631 EX 112LSA roller with some ported 346 chrysler iron heads flowing 280/180 at .600.with the chiller the intake temps went from 270F to 130*
good luck with your build!that was with 12lbs of boost.
that was with tap water !just think with ice water the temps could be!or E-85 and a chiller.i have had the chiller for 3 yrs.E-85 is just coming around.i will get there next yr i think converting the carbs.or new 1's.interesting, i got even colder intake temp in my motor (120 at wot) without a chiller but i use e85 for fuel. why not use that fuel instead of a chiller?
