1 - 6 of 6 Posts
470 inch bbc going in a pull truck. Out of the hole at 6000 and runs to 8700. I've got both intakes and the both fit well so its a matter of picking one and putting it on. The 454r has been port matched and the other is out of the box.
What heads? Whats the mcs? I would think that the Super Vic. would be the way to go, but this will depemd on what you have down stream that will more less make it work or chooke it up.
Discussion Starter · #4 ·
More details.
-4.560 bore x 3.6 stroke 14:1
-merlin cast iron 105cc x335cc intake runners(best i could measue) flowing in the 400 range at 800 lift
-270ish 280ish @50 .820 .820 110ls roller
-runs on gas
-4500 carb
1 - 6 of 6 Posts
