I almost don't want to post these silly questions after reading several of the threads in this forum. I have said '81 C20 with the original 292 I6 and a 3-speed. I decided earlier this year that instead of rebuilding the 500k 292, I would take it up a notch and go with a big block. I will use the truck for weekend cruising (scrub miles off of my daily driver Ranger) and for the snowy weather. I will probably only lift it 6" max with 37" tires. Don't plan to spin the 454 much; probably 6500rpm max. So, on with the questions.
I just replaced the heater core a month ago. When the big block goes in there, should I put restrictors in the heater hoses?
Also, I am looking at carburetors for the 454. It's been a while since I messed with one. Carb formula is pointing to a 750cfm unit. I don't plan on doing any mudding with the truck, so would a Holley DP work with what I intend to use this truck for?
I can give more specifics on the build. I know what parts I want to get; however, what I can actually afford and purchase in the end may be different. Thanks for reading this
Chickenbone
Chickenbone
