1 - 16 of 16 Posts
What is the ideal compression I've heard anywhere from 8 to1 to 10.5 to 1 need some input for this build
My build is the same 410 lsx but with a xb105 and we went with 10.5 to 1. I am going to use c16. This is my version of a all out heads up build but opions will vary. Good luck. Give more details for better answers on here.
Sorry fuel is going to be E 85 also class is goin to be heads up
Chupa Cabra
10.5:1 sounds good to me if not more! You could run E98 and be well over 11:1 safely I would think with proper cam timing and ignition timing.
Our turbo E85 A/W intercooled combo is a 10:1 but we wanted it concertive. We were recommend by the piston manufactur that a lot of builders are going as high as 12:1.
As has been said, just stick with 10-10.5:1 and let the blower do the work for you. No point in goin' much higher with the already boost-friendly characteristics of E-85, unless you just wanna' be able to tell the 10:1 guy that "I've got 11:1!"
---==Temio Williams
Yuba City, CA
---==Temio Williams
Yuba City, CA
Gott'em by an inch!lol:smt081
:smt082:smt082:smt082 I won't fold my unit in half for anybody!
I would be careful on compression. The LSX is sensitive to compression and timing already.
I have a 388ci LSX engine with an F1R and 11.5:1 compression. It's got a narrow tuning band.
I'm building a new 427 engine and it will be 9.5:1 with an F1X
can you get a little more agressive with fuel inj and the knock sensors, exhaust sensors working-i always ran carbs, so i had to do the timing and jetting
E85 is your friend tho:) better than gas for detonation.....
Chupa Cabra
What fuel?
1 - 16 of 16 Posts
