1 - 19 of 19 Posts
we'll i tore down my 406 and did a cam change . engine ran good but almost everyone agreed the cam was to much so i changed it . now i was running a stock victor jr that did not match the heads well so with my engine should i do a good port match to my victor jr or swap to a different intake. this engine is in my 68 chevelle street /strip car. it will be running full weight ,3"flowmasters,5000 stall, 3.90 gear,6600-6700 rpm max
406
stock block
eagle crank and 6.00 rods.
probe flat top pistons(10.8 to 1)
stock unported brodix track 1 215cc heads.
comp solid roller 252/258 at .050,630/630 lift 106 lc installed at 104 ilc
stock victor jr intake, 750 to 850 holley.
1 3/4 headers
the engine ran 11.16 at 123 in my camaro with only 2 changes one the camaro ran 1 7/8 headers and the cam was a 276 282 at .050 640/640 lift. im looking to run as fast or faster with the new cam in my chevelle the cars should weigh very close to the same. thanks.
Wow 3500lbs 69 Camaro seems heavy ..I would say that motor combo for that weight ran pretty
Good ..my bodies 70 chevelle small block car with a cage is around 3450lbs
406
stock block
1 3/4 headers
Jus lookin @ your rear gear I'd say you could use a set of 456's I'm sure your leaving some on the table with a 390 gear .It can't be goin threw the eye's at your max rpm .And to answer your question ya I'd port match the intake and give it a true trial .
No way with a short tire and a 2.48 low gear, if he changes the rear gear it will ET and MPH the same.
What we have found is you cant stick enough rear gear in a street car to lock the converter up so you might as well ride the converter in high. We have changed from a 4.10 t oa 4.71 and not seen a difference in anything ET or MPH with a car that is dead hooked on both gears
Discussion Starter · #16 ·
im sure a 3.90 gear will not get me thru at max rpm id say around 6100 but its where im going to start so its driveable i might go to a 4.10.
Jeff sound more like the converter isn't working for you if you can't see a difference .When I just change tire height I notice a difference .I've also seen Jay's Nova change as much as two tenths because of a difference between 28 and 29 tall tires
1 - 19 of 19 Posts
