Hi guys
I have a problem with a turbo 402 I'm tuning for a mate. My thoughts are cam timing is out so il need to check that
Combo is 402 Gen iv block
Ls3 heads and manifold
Bullseye billet 80mm
Comp turbo cam mid 230s and 624th lift
1 3/4" headers with 2.5" crossover.
60mm gate
3.5"down pipe.
T400 trans with 9.5 5000rpm converter.
With 9psi and 16deg on e85 it made 520whp
But power peaked at just over 5000 rpm and just fell off.
Ive since added 4 more degrees and 3psi and only gained 25 hp. And the power cure is still shit falling over at about 5500.
What's everyone's thoughts
Should be making like 700 I would think
60mm gate
3.5"down pipe.
