1 - 20 of 27 Posts
Finally getting back to 449 Cleveland. 4.055 x4.35. Chi 4v heads with some grinding. Old school ur19 with dual 6464 carbs. Last combo made [email protected] Scaled duration back on this cam to match my heavy tub a little better. With the bigger bore we were able to get rid of popup pistons for cp flats. Will be interesting.
Discussion Starter · #8 ·
Thanks guys. Best run to date is [email protected] Car has all factory glass and interior. Factory am/fm still works. I broke crank late year before last and it’s been on back burner. Just picked up new molnar rotating assembly. This will bump cubes from 438. We reconfigured camshaft as i was running a old crane roller 727 lift and [email protected] Hoping to get big girl out of gate. I use 10 inch slick in stock fenderwell with slide-a-link bars.
Discussion Starter · #11 ·
Lol. That guy is good friend. He was just trying to dial nos in on 302 but didn’t quite get it figured. He would have narrowed the gap.
Discussion Starter · #13 ·
Cc.’d heads this morning. 61cc. So with flat top we looking at 13.3:1 just about right.
Discussion Starter · #18 ·
77 400 block 4.055 bore
Grouted to 1” below deck
Splayed 4 bolt main caps on center 3
Stock caps on outer two.
bushed lifter bores
Mpg cam and roller lifters
Flat top cp pistons for 13.3:1
Chi 4v heads severely massaged
Molnar 4.35crank
Molnar 6.8 h-beam
Melling hv pump
Crane wide bodied rockers. 1.73
Jomar girdle
Smith Bros 3/8 .135 wall pushrods
Home built pan buy outlaw marine jets
17/8 header to two inch primary. 3.5 collector
1970 era ur19 tunnel ram
Dual 70 era 6464 1050’s.
91 Mustang, bracket car
bushed lifter bores
Molnar 4.35crank
Molnar 6.8 h-beam
Melling hv pump
Jomar girdle
Can't wait to see how this turns out !
Discussion Starter · #20 ·
Dyno date may 26. Old combo had 4.050x4.25 and 14:1. [email protected] and .727 lift. 703hp. Hopefully we get close. We are hoping to get more tq through mid to get heavy ol girl moving. Our da doesn’t help here typically 4500+.
We added lift shortened duration and moved lobe sep to 106 and give it 4* advance 🤷🏻See what that does. I know one thing when you tell people its a old 400 they think im fibbing!!lol
1 - 20 of 27 Posts
