1 - 20 of 26 Posts
Eagle lift here for 10+ years and has been working well. It gets used lots for restoration work, mechanical work, and storage.
Friends are happy with Bendpack, and Tech lift as well.
Discussion Starter #10
u make me want a iroc again chad..didnt you say one is getting a 383 on fb?they look pretty org.
The front one is 100% original.
The back one I have done a lot to it. Ported the heads, ported TPIS Mini Ram, cam, 8mm valves, steel rockers, headers, billet TPIS throttle body, TPIS chip, 3" exhaust w/spintech, converter, new 4L60 transmission, aluminum drive shaft, new wheels, lowered it, new fuel pump, and just recently found a rare Dana 44 we put under it.
Pics of the Mullet or it didn't happen.
Nice set-up!
Might be a stupid question but do the posts need bolted to the floor? I have in floor heat and would be nervous as hell drilling into the concrete. It looks like you don't have them bolted down in the pic
Looks Awesome!
What kind of interior siding is that on the walls and ceiling?
Is it just the same siding you would use on the exterior or?
Nice set-up!
I've got a 4 post and a lift covered up waiting for this garage to get done (logs). My understanding was that the 4 post did not have to be bolted down.
Discussion Starter #20
Nice set-up!
You can, I didn't. One reason I liked this lift is because of the box around the 5x5 post. This is the debate with them, being a channel post is stronger.. Anyway, you run the lift all the way up and back down and all 4 posts square themselves up.
1 - 20 of 26 Posts
