1 - 6 of 6 Posts
3200lbs 53 on the nose it got a 53 3/4 ic at 6in 108 in wheel base on 28 10.5s makes about 1400hp it goes out about 15 ft and knocks the tires off about ever time if i took the ic to say about 59 at about 7in would it help thanks for any suggestions before i lose my mind.
had same problem when the 2nd stage came on , check your ride hight should be 1" differents front to back ( i measure off the rockers ) , front end travel, and try a lower ic , fix my car
Needing some wheel speed, try lower wheelie bars and more tire pressure - although i don't know a thing about a 10.5 tire car. I'd go further out too, is it excessive on the wheelie bars? Thats an indicator too.
1 - 6 of 6 Posts
