1 - 14 of 14 Posts
I've got a large frame 91.5mm precision on my car, I can only fit a 4 inch down pipe in my chassis with the turbo in a front mount location. I'm kicking around turning it sideways to fit a 5 inch. Am I killing alot running a 4 inch?
From everything I read, 5" is optimal. I ended up doing split 4" out to each side, which again (from what I read), is about the equivalent to a 5" DP. I will let the professionals chime in though! 4" probably would have been fine on mine, but I tend to try to do the best route on everything.
5" is best case scenario. Depending on the length of your down pipe you MIGHT get away with it. Woolf has 4 1/2" as well if you can fit it.
I'm front mount with a front exit. So I think total overall length is roughly 20-24 inches of pipe to exit the car. There's no room under the hood of a 64 chevelle lol!
64 Chevelle is way bigger than a 66 Chevy II, LOL!! Front facing twins with 5" on each.
99696
  • Like
Reactions: Boosted Bullet
As a 65 Chevy II owner, I can relate. Full 4" all the way to the trans xmember. Dual 3" from there to the rear bumper.
99814
99817
Discussion Starter #11
I've got the turbo in the grill itself and front the flange to the fittings for the water I've got 7.5 inches of clearance.
Discussion Starter #13
I tried that and physically couldn't it fit it. I can fit 4 inch though. It's tight but does fit.
1 - 14 of 14 Posts
