i know its small , but is it big enough for a 250 hit
its kind of a hidden system and space is tight
the whole fuel line length will be about 2'-3' long , reg is mounted to the pump and i need a 2' length from the reg to the solenoid , then short line from the noid to the plate
can i use -4 from the reg to the noid ?
i've done it on efi cars , but they are much higher pressure
