1 - 20 of 40 Posts
Rules for 4.90 ,5.90 & 10.0 ars as Follows,Pro Tree , Doorcars Only,No Throttle Stops, Nitrous ok-if you need it to run the number,All Run Field -You pay you race -Qualifying is only to set the field, #1 Qualifer 150.00 winner in the 4.90,2000.00 Purse for the 4.90 class ,Not Sure about the payout for the other classes but I Know it will be high as the car turnout for the 5.90 class is huge ,as is the 10.00 Class . Lets Race I'm Tired of Bench Racing!!
thought they where going to have a 4.10 class also.
Is this information posted on the VMP website with rules and payout? Maybe I just missed it.
Discussion Starter #12
Foolishpride Whats the car runin the 1/8 now? DBN 10.0 Class Will Be .500 Pro Tree . Rules should be Posted By Weeks End . / 70Z28Camaro Yes They are going to have te 4.10 Index on the same date as the 4.90, 5.90 7 10.0 Thanks
Discussion Starter #13
Entry for the 4.90 is 75.00 and Entry for 5.90 should be 60.00 And entry fee for 10.0 I Believe, will be 50.00
Discussion Starter #16
FoolishPride You would probably need a 300 Shot to get you to the 4.90 number, I think you might would be best to back it down and run 5.90,Short shift, Add weight ,Timing Retard Etc.
Brian, was just curious what you thought it would take. Not planning on trying to race under those circumstances, but may make an attempt at that number at some point. Oh yeah, just to add to the equation, I am spraying on alcohol.
It is all set up my brother. Carb with an Alcohol N20 setup. Have only hit it twice. Once in high gear only and picked up almost 11 mph, about 2.5 tenths over a motor run that day. Then tried to leave on it once and stood it straight up (no wheelie bars on). Will not do it w/o them again. That was with a 175 shot according to my cheat sheet.;)
Discussion Starter #20
Herman should be right in the hunt with his new car for the 4.90 class, Gordan your car runs right strong as is I'd try short shifting it for the 5.90 class, lot of people building cars for this series in our area, 2 people bought cars for the 4.90 class that I know of .
1 - 20 of 40 Posts
