any body here using this kind of this setup?
what oil pump kit are you using & how is it working out for you?
what is the oil pressure like at idle <hot & cold>?
what oil weight are you using?
does your engine run hot now or is all good?
what modifications you had to do to use this system?
what is your experience with this setup?
any pics & input will be appreciated?
thanks
thanks
