🤔 regular dry sleeve isn't recommended for going to the point of, Or more than what your thinkin.
4.200 dry sleeve is a No Go... can it go that far? Yes but it'll be thin. 4.190 - 4.195 is about as Far as Steve told me on memory with Any Ls dry sleeve. I even asked about using the spray on (wire-arc cylinder liners) used with the 5.4 gt 500 aluminum block with aluminum sleeves. As To go with more bore which be a thinner sleeve.
If a person would like a 4.200 bore that means:
Dart Aluminum sleeved block or Dart iron block
Steve designed the Dart sleeve to go to 4.220 both blocks I believe.
At 4.220 or more the head gaskets get thin to be considered reliable for Daily use.
From Steve...😉
