1 - 4 of 4 Posts
Just recently purchased a set of 3754 MT Et Streets, I was intentionaly trying to get the 3754x ET Street radial PRo but bought the wrong ones. Now im in between using them or loosing a bit of money and sending them back. I have a 94 Toyota Supra , the car weight is about 3300-3500. Car has been [email protected] with consistent 1.4x 60s with about 830-900HP through a TH400. I was running a MT ET Street Radial but on the street if i turned it on my highest boost setting +/- 1080 whp , the car would spin the tires every time. Would these ET Streets perform better on the street than the ET Street Radial ? Should i use the ET Street Radial Pro instead ? I dont mid the wear , and the car has skinnies in the front idk if that matters.
put the pro on it.. you will be much happier.. customer just put pros on his 1500 whp gtr and he loved them..
the bias will be more forgiving on un preped tracks and the street but will handle like a 48 hudson hornet
Be carefull with a pro radial and stock/TRD diff. Might wanna look into DSS rear kit to run that tire.
1 - 4 of 4 Posts
