93 oct fuel @ 18 psiWhat fuel are you running
what number NGK ?I run ngk's at .028 with 22 psi with a ysi
MSD 6AL BOX3932 , gap to be determined by ignition box .![]()
Ngk r5671-8 also with msd 6al boxwhat number NGK ?
I would think you need an r5671A-7 ngk plug and gap them around 28-32
picking some up tonight ..thanks guysI would think you need an r5671A-7 ngk plug and gap them around 28-32
You did not say much about the coil. With just a 6box I honestly would start the gap @ 20.MSD 6AL BOX
First off, sorry OP for hijacking the thread a litteYou did not say much about the coil. With just a 6box I honestly would start the gap @ 20.
The NGK plugs are right but the CD box is not your friend here. Good luck.
Sickfox
Has anyone got a performance gain going from an 8 to a 7 heat range plug? and how much?
