1 - 6 of 6 Posts
How much flywheel hp can a sbf with a large solid roller make around 25 lbs boost none intercooled. know people have used these and I wanted to get a real world idea.
hopefully a lot it sounds like the set up i am just about to get running in about a month. i am not intercooled though
a top efi renagade car makes about 1000 to the wheels with a 306 550 lift hydraulic roller and a holley intake without a cooler... big cam and a good intake should be able to make 1100 to the tire
There was a guy with the same setup running nmra drag raidal at bowling green last year. I believe he was running around 8.50's which would put him probably around the 1,000hp mark.
this past week end one renagade car running 8.30 ish or some thing like that
the right set up , with the right amount of cash should get you 1000 to 1100 hp
1 - 6 of 6 Posts
