MIGHT NEED A OIL RESTRITOR KIT IN THHE BLOCK?
Mine's not a sig picWait until Monty and Bacarty see this. They will both have a heart attack before they can respond to those sig pics.
Its a fakeNICE CAR! AND RARE
i tried throwing the trans in neutral and letting it idle to see if pressure came back and it didnt come back within 5 seconds. as for the rest, im not sure i bought the truck running so id have to tear into it to find out. i am planning on pulling the pan soon so i will check all of that then.I would guess that the pick up is to close to the pan- or did you forget to put the gaskets on the oil pump to block&pick up tube ... i seen the plugs on the front of the block by the timing chain pop out ..i always tap and put screw in plugs in them
If you need any help let me know- i will try my best to helpi tried throwing the trans in neutral and letting it idle to see if pressure came back and it didnt come back within 5 seconds. as for the rest, im not sure i bought the truck running so id have to tear into it to find out. i am planning on pulling the pan soon so i will check all of that then.
X2Ristrictors possibly or the pickup screen maybe too close to the pan. And sucking it to the pan.
That does not sound good. Was this motor "professionally" built?thanks for the help everyone, it ended up being a handful of gasket material and silicone plugging up the pump pickup. i cleaned it all out and pressure is good now.
