1 - 20 of 89 Posts
Banned
> 351 MAXX Block <
wondering about an off the shelf 6.450" rod for sbc
i see a 6.450" LS rod
is it the same as an sbc rod ?
There are some small differences but was told that they will work. I looked @ SBC honda rods on a Ls 4 in crank. Eagle has there 6.460-6.560 rod with both a Honda rod journal and standard 2.10. I called and asked Eagle this question yrs ago. Give a manufacturer a call.
6.460 CRS6460O3DL19 640g H-Beam 2.1000 0.927 1400 hp rating $688.00
6.560 CRS6560O3D2000 650g H-Beam 2.1000 0.927 1300 hp rating $665.33
Doing the math real quick for the correct height.
4 inch crank with 6.460 needs 1.29 pin height to = 9.75
Banned
thx for info, wanting to do a 451ci square deal (4.155"bore x4.155"stroke) with a 1.55 min rod ratio, will look into LS rod options more.
Banned
hey BBF612, was searching and found your old post...
https://www.yellowbullet.com/forum/showthread.php?t=1737578
would be interested in seeing the LS rod pics you posted, is it possible to repost them here?
found 6.400"sbc and 6.500" sbc rods i could also use but would prefer a 6.450" length
I still have the LS K1 rods they are 6.450 long, They are new but the bolts were removed, I have a set of MS Aerospace rod bolts that fit them which are also new.
Banned
Discussion Starter #11
will send you PM
Banned
Discussion Starter #12
Does this block even exist? I called and was told it was a typo.
dont tell me that lol... talked to Kevin/Troy about this raised high deck 351 super maxx block back when i got my other... > 351 MAXX BLOCKS <
will have to call FPS this week...
:smt023
seen the 2 blocks are NOT the same castings in pics/adds...
> https://atracingworld.com/ford-351w-windsor-b-4-125-m-2-749-dh-9-750-billet-main-iron-engine-block-machined/ <
> https://atracingworld.com/ford-351w-windsor-b-4-125-m-2-749-dh-9-500-billet-main-iron-engine-block-machined/ <
Banned
Discussion Starter #13
Shrewd Negotiator
So it doesn't actually exist then and it is a fuckup?
Have you fixed all the posts you've made about it, advertising it like you do the rest of the offshore junk you continuously peddle?
Banned
Discussion Starter #15
what a fucking loser TROLL you are lol,
Banned
Discussion Starter #18
I'm Looking in the mirror again and see a hypocrite
you fart block fanboy hypocrite Trolls just cant help yourselfs EH lol
why is it? you internet forum salesmen/fanboy Trolls selling the crap out of you barns/sheds online can't ANSWER a/the simple question we have asked for MANY YEARS NOW ...
with NO ANSWER to the ONE simple question from ANY! of you internet forum Dart/Part peddlers ??? ...
"WHY are there so many complaints of BUSTED/CRACKED DART BLOCKS on yellowbullshit???...
FACT... www.cncblockne.com CNC Blocks NE and Carl Hinkenson ... that spamed and was banned from some forums for his Bigot/Racist/Islamist lying BS, NEVER brinell tested Kevins/Troys MAXX block and thats a FACT. The brittle DART blocks the Bigot/Racist Carl Hinkson and his Bigot/Racist/Islamist YB internet Dart Dealers, like (#2,#3 fanboys PuRpS & SGracing) buddys push on online to everyone have had way more issues/the same cracking issues as the Brittle Cracked Liberty Bell.
FACT is some of these Bigot/Racist/Islamist (hiding behind america#1) internet DART DEALER trolls (and there Bigot/Racist/Islamist online YB redneck Dart fanboy trolls) have continualy Bashed and FALSELY BLAMED other companys products that they dont sell instead of dealing with the many online complaints of problems with the Dart Blocks Cracking since 2006 which NO YB dart dealer/peddler troll has ever explained as to why so many Dart Blocks Crack.
here's just one example (post #81) ... of dozens of cracking Dart blocks in the same spot... https://www.yellowbullet.com/forum/showthread.php?p=20529242#post20529242
("I also have at least 12 racers that have broke their dart blocks as I have and the problem is the block. Burning a plug and blowers blowing up I'm sure don't help but from all that has come forward to say their blocks have broke in the same spot leads me to believe the block is failing.")
Lyle671's Dart block ...https://www.yellowbullet.com/forum/showthread.php?t=770506
nos stroker's Dart block...https://www.yellowbullet.com/forum/showthread.php?t=465317
and a few more CRACKED DART BLOCK links...
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=27836506&postcount=123
cracked dart...
https://www.yellowbullet.com/forum/showthread.php?t=1096170
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=20441242&postcount=14
cracked dart
https://www.yellowbullet.com/forum/showthread.php?t=1370489
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=44178754&postcount=21
cracked dart
https://www.yellowbullet.com/forum/showthread.php?t=1469234
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=3730325&postcount=10
cracked dart
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=26057850&postcount=3
cracked dart
https://www.yellowbullet.com/forum/showthread.php?t=356696
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=26054754&postcount=122
cracked dart
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=20571458&postcount=84
cracked dart
https://www.yellowbullet.com/forum/showthread.php?t=455927
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=39247522&postcount=12
cracked dart
https://www.yellowbullet.com/forum/showthread.php?t=257285
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=20575866&postcount=85
cracked dart
https://www.yellowbullet.com/forum/showthread.php?t=424438
cracked dart
https://www.yellowbullet.com/forum/showpost.php?p=20618090&postcount=100
main break/cracking issues even with the Aluminum Dart Blocks...
Etextor's BBC DART ALUMINUM BLOCK CRACKED - Yellow Bullet Forums
Insane's Cracked Dart Block...https://www.yellowbullet.com/forum/showthread.php?t=623577
...> cracked dart blocks, cracked dart blocks, cracked dart blocks <...
also find it more than moronic for some with there "China Junk" cast k1tech, scat, eagle, callies, rpm, manley, lunati, cat, molnar, wiseco, ohiocrank cranks & rods
typing on there China made computers&ipods bashing/crying about other american companys products like the fps/rpm 351 maxx block
when the factory Chevy LS blocks that are so popular with the 7sec $200 junkyard LS crowd were Cast in fucking... MEXICO. LOL
and lets not even mention all the other offshore Asian parts from...
weiand, msd, mrgasket, bbm, fordracing, flotek, patriot, srp, holley, compcams, profproducts, rhs, felpro, arrow, afd and many others eh"
... instead there is supression, threats, lies, bashing, trolling and this ...
is your dart product so fucking inferior to the boss/world/maxx blocks that this is all you dart fanboys got is to supress, threat, lie, bash, troll ?
Banned
Discussion Starter #19
Just saw this thread and the 9.75 deck is great, big question to me is has the cam been raised or still in stock location. Tough to get more then 4.25 stroke without a raised cam.
1 - 20 of 89 Posts
