1 - 6 of 6 Posts
I have seen one of these before and I believe it was in the 4.56 ratio. I don't think it was ever something that was in mass-production. What ratio would you want?
no just for a more street strip car , have a center section with 4.56 pro gear, would like to just swap gear set, if won't find one, will just run pro 3.90 keep same support and yoke
I would recommend just running a standard street/strip gear with a 28 spline pinion. You can purchase conversion bearing/spacers to run this in the 35 spline pinion support, all that you would have to change is the yoke. Your final price in doing this is going to be around the same price as a big pinion 35 spline pro gear, not to mention the street/strip gear will hold up ALOT better and last ALOT longer on the street.
1 - 6 of 6 Posts
