1 - 20 of 23 Posts
Anyone remember the thread about this? Someone was claiming a 347 is gonna make more power than a 351 in equal trim? Cant find it to save my ass. Someone add a link please- Thanks
I say yes! If it is a stock crank,rods and std weight piston in the 351. The larger mains and heavier rotating assembly alone will not offset the 4 extra cubic inches.The 347 will rev quicker and make more power.
In theory! lol
But the 351 wont split in half at 500hp.LOL
Banned
In theory! lol
x2
or just get yourself a small main dart iron eagle to work with....itll help offset some of the heavier mass
:butthead:
could be mexican 302 -usually Windsor means 351.
how about rod ratio, which is better? there is a lot of side loading on a 347 too
The rod ratio is still better than a BBC so I would say its not really an issue.
Don't a 302, and a 351 both have a 4" bore?
Yes but once you make it a 347 you are now going .030 over. Or if you are running an aftermarket block you could do a 4.125 with a 3.25 stroke to make a 347..:)
1 - 20 of 23 Posts
