1 - 6 of 6 Posts
Going to the track soon and wanted to know if i should use my trans brake or should i just go off of the footbrake with these Mickey ET Street II drag radials? 345/35/18 on a C5 corvette with th400 and twin turbo's. Does this tire need to be hit hard or just eased into the power? Any info would be much appreciated. Thanks guys!
You need to be able to "hit" the tire but the load needs to stay applied. This has a lot to do with the tune-up in the car and shock settings. A lot of guys use a trans brake, but I might suggest you walk before you run.
Thanks,
Jason Moulton
Hey Redbird...have you considered the LG spindle that allows you to run a real wheel and tire combo. With the power and ET you are looking to run....I would be looking at a 15" combo. The spindle allows you to keep your stock brakes and e-brake.
Here is some vette tire porn....with the spindles...
http://imageshack.us/photo/my-images/845/realtires4.jpg/
http://imageshack.us/photo/my-images/196/realtires3.jpg/
http://imageshack.us/photo/my-images/269/realtires2.jpg/
http://imageshack.us/photo/my-images/714/realtires1.jpg/
http://imageshack.us/photo/my-images/23/realtires.jpg/
Good luck with your build...
Yeah..I hear ya but....9.5's and 8.9's are worlds apart. I'm pretty tuned into the vette track scene and there are a handfull of guys going mid nines on 17 & 18 dr's but...from reading this guys sig and seeing what number he is shooting for....save yourself the headache and do it right from the start.
Arun @ CCA
Rodney @ RPM
Jay (4DRush)
Jay is already in the eights and the other two are knocking on the door...these guys switched to the spindles and it seems to have been a smart move.
And the other thing is the rotating mass issue...C6ZO6 (replicas) 18x11= 30lbs M/T 345/35/18=35lbs total 65lbs per side.
Weld prostar 15x10=13lbs Hoosier 325/50/15=28lbs total= 41
So...24lbs of rotation mass per side...I think the formula is 1lbs of rotation is equal to 6lbs of static weight..(estimation) 6 x 48lbs = 288lbs of extra weight. Not to mention lack of sidewall issues...
Thanks.....But I do agree the dr's are awesome...
1 - 6 of 6 Posts
