1 - 10 of 10 Posts
I have the BF 325/50/15 now and was wondering what would be the diff in the 2 Mickeys in 325 and the 315's? Is the 315 that much of a bigger tire, I'm sure the width will fit but there's 2 inches of height and 7 inches of roll out diff.
Most of the 315 cars ive seen are running the 14 in rims and the 12 on the others
I normally run a 10.5/28 drag slick on the 8 1/2 rim, just worried about the diamiter and IF the tire grows?
I have a 8 1/2 rim now and figuring Ill prob need a 10 in, its a 70 chevelle
Thanks for any input
Rob:)
Rob,
The P315/60R15 is a significantly bigger tire than the P325/50R15. The tires do not grow, but I would recommend running them on a 10" wide wheel minimum.
If you have a P325/50R15 on the car now, I think you would be happy with our version, even if you go to the P295/55R15.
Thanks,
Jason Moulton
thanks for the info, I could put something bigger than the 325, but the height on the inside might be too close, I wouldn't mind the roll out of the 315, but to be safe prob stick with the 325's. Just need to find a deal on them now
Rob:cool:
Is there any rebates out there? My warehouse just went from 188.98 to 204.00 each,shipped would be 430.00:eek:
if you can fit a 29.5 x 10.5W (3062W), would it be safe to assume that the 315/60/15 should fit as well?
The biggest slick Ive run is the firestone 28/10.5/15. That tire when the car twist, the rh front edge of slick would rub the inner frame some,
The pick i have of the 29 Im not sure whats been done to that car to fit? it was just at the drag strip.
The concern i have is the dia rubbing the inner fenderwell ,I hate to have to c notch the frame just to fit that tire.
I would really like to test for a old/bad 315 before buying a new set,
My warehouse with shipping is $398 to the door,I guess I could try them and if they didn't fit dump them
Rob
I have a 70 Chevelle like you and I have a 29.5 x 10.5W on a 10" wheel and it fits great. No rubbing, just rolled the lips n the 1/4 panel.
the slicks expand, that is why i don't see a problem with me fitting a 315 radial. just thought i'd ask though
Discussion Starter #9
Thanks for all the advice, I ended up with the 325/50/15, wow these tires are day and night diff compared to the BF,Im not sure how they will hook off the line,but bet its close to my slicks
I have a 8 1/2 Convo pro rims and the section width is 12 1/4 if I go to a 10 inch what would that change the section width to??? 1 1/2 wider wheel
Im also want to change/update wheels to some beadloc weld etc, Do anybody have any suggestions?
My 325/50's on my 12" champion beadlocks.
1 - 10 of 10 Posts
