This.no pics of mine yet, 15x10 in wheel with 6.5 bs. mini tubbed with offset lower control arms. i also use wolfe's adjustable spring mounts. its pretty close to the front and back of the wheel wells but i have tons of room on the inside
I narrowed my rearend 2" on each side, used a 15x12" 7.5" BS wheel. I'm having to relocate the control arms to between the torqueboxes and frame, control arm brackets on the rearend were moved in 1".no pics of mine yet, 15x10 in wheel with 6.5 bs. mini tubbed with offset lower control arms. i also use wolfe's adjustable spring mounts. its pretty close to the front and back of the wheel wells but i have tons of room on the inside
There are some pics and links in here:I would also love to see andrew91gt's set up. I haven't seen that yet. pics???
i mini tubbed mine and still have the backseat....it just barely fits but does...i have 29x14.5 hoosiers qtp's on 11inch wheels.I am in process of same size. Just waiting for some snow to melt to get project started. I have done A TON of research on what will/wont work. All the info and pics I gathered shows that 15x10 with 6.5 backspacing will fit when you 1-cut the bump stop off 2- cut or "modify with BFW the front inner/lower portion of wheel well 3-roll the fender lip. That routine is pretty standard from my extensive research. If it works depends if you like the way it looks along with just not rubbing. Personally I would like to have tire in at least a little more. I am not going to mini tub, I want my rear seat for astetics. No use for rear seat for me, just to have complete interior around my 10 point. I will even consider a 9" wheel. I will post pics once I get it started in March. There is a ton of info if you search on yellowbullet and thirdgen.org. Good luck, cuz i'm in same boat.
My car is going in for this very shortly. I won't be notching the frame however.no pics of mine yet, 15x10 in wheel with 6.5 bs. mini tubbed with offset lower control arms. i also use wolfe's adjustable spring mounts. its pretty close to the front and back of the wheel wells but i have tons of room on the inside
onefast68. Your badass car is one of the third gens I saw. I love it. It is fast as fck 2! I should have been more specific. I want the rear seats AND i don't want to cut up the interior plastic around the tubs. Just me.
I'd like to see the plastics inside your car if possible.i hated cutting the plastic as well..after i done it though it looks great...i have had several people look at the car and i asked if they could tell what i done from the inside and all said no.i had to show them.LOL
what size and offset are those rear wheels?if you keep the lca in the true stock location with the offset lca, the tire will sit like this: and this is with the tire approx 1/16" off the lca and mini tubbed.
What section width are those tires on a 15x12? I estimated 14" when doing the math for the backspacing on the wheels I'm going to run.15x12 with 6.5bs.
