1 - 17 of 17 Posts
El Diablo Blanco
I'm pulling up both part #'s for a tail light bulb on my wifes Jeep, what is the difference? I've never bothered trying to find out what the difference between the two is.
El Diablo Blanco
Ok thanks. I'll grab whichever one I see first at the parts store then.
You need the CORRECT number for your vehicle or else it will still show you a lamp is out on your lamp failure circuit board in your counsel.
The difference--sure is the wattage, but it also has different resistance---which in turn will illuminate your message board.
I love it when something as simple as a lamp failure sends a guppy down the tunnel to no end----simply watch the tail lights of "self repaired" vehicle--you just have to laugh!
El Diablo Blanco
Discussion Starter #10
Ahh..that +1 is what fucked me up. Damn math.
It makes sense about dual/single element.
El Diablo Blanco
Discussion Starter #12
It's got a separate bulb for turn, I need dual filament for park/brake I guess.
DEEZ NUTZ
You can use a 3157 in a 3156 but not the other way around. It does not work for the 11 series bulbs though.. But to answer your question for park/ turn yes you would need a dual filament bulb
1 - 17 of 17 Posts
