1 - 20 of 36 Posts
· Registered
I have a 302 based engine. It is a mexican block. I have a main girdle on it and forged internals. I know of the limitations of a stock standard 302 block but whats the limit with this combination? I was wanting to run 8.5 limited and already knew I was taking a knife to a gunfight but If I can keep from scattering parts everywhere that would be great. The engine dynoed at 640hp before the heads were ported so is it tapped out or can I spray a little bit? Thanks for any help.
· Registered
what i was told a while back is the mexican block is about as strong as the 351w stock blocks.
· Registered
It will hold a little more. But when it goes it will go big. RPM is the big killer with em.
· Registered
Guess I'll try her out and diaper it up.
This ^^^
I am a die hard 8.2" Deck guy. If I was going to build one for the Ky. limited series, I would be searching hell and high water for a boss 302 block. The one with the 4 bolt mains.
Best of luck with the "El Hecho"
· The Medcine Man
BUY A NEW BOSS BLOCK ....... DON'T WASTE ALL UR internal or your car..When I bottom END COMES OUT OF THE BLOCK AN OIL'S DOWN THE TRACK ...just my opinion .
Illegal. Can not run any aftermarket block be it Ford or Chevy. It has to be a passenger car or truck block. A boss block is just an aftermarket block made by the factory just like the bow tie blocks are.
· Registered
Build a 351 and be done. Or BB.
or give the 8.2 way less weigth than 3150lbs and were talking 2800 or lower...Were talking about where they can have a chance to compete against 351w or SBC,BBF,and BBC without killing the block.I too like to use what I already have laying around in the house.
p.s. I do think diaper need to be in the rule too.
· Registered
At 640 + HP and that block you will have "rod windows" very quickly.
After you get the "rod windows" all you will need is a scoop shovel and a 55 galllon drum to clean up the big mess.
PS. Don't forget a good supply of kitty litter.:)
· Registered
The whole Mexican block thing is like calling one retard smarter than the other retard. I completely understand budget concerns but It's painful to keep seeing this come up over and over on the internet.
· Registered
Some of the longevity issues depend on the machine work, how the engine is mounted, the tune and so on. Some people can break cannonballs with wet spaghetti, others can screw some shit together that is near indestructible.
1 - 20 of 36 Posts
