1 - 20 of 20 Posts
I am looking at changing the cam in my Chevy 302.
This is what I have 11:1 comp AFR 210 Race ready heads victor Jr. with a 1" open hole spacer, a 825 double pumper Demon carb.
The Cam I have in it right now is a Comp Cam XR292R it has a lift of .582 intake .588 exhaust. Duration at .050 is intake 254 exhaust 260 with a LCA of 110.
What would be a great change or is this the right one?
What's your stall and shift point?
My stall is what ever I like! lol It has a M-22 in it with a 4:56 rear gear.
Shift point right now I shift at 7200.
Gotta love sticks! You want to turn that thing a little harder?
What are the rockers and springs? Old AFRs or are they new ones?
I have Jesel shaft mounted 1.5 they are the older AFR's bought then in 2004 they have 225lbs on the seat and 550lbs open. Yes you have too love a stick car! lol
No one wants to help?:(
that cam is a street roller,incorporating gentle lobes for longevity.i have used it before in a few applications and it works well.one thing i might try is upping the rocker ratio,1.6's work well,increasing the lift and adding a couple of degrees of duration as well.im wondering if your short block is able to handle a higher shift point,thus a cam change would be beneficial to you.with your cubes and your cylinder head configuration,its possible to make power to 7500.with your present cam,you are leaving alot on the table.
The nice thing about the SBF is the cam diameter is big so you can still get some big lift with it with 1.5's. Hell we can go .700" lift and turn that thing some real RPM and let it eat. If you want something look me up, shouldn't be too hard.
Butch
A perfect camshaft for your engine would be this following Crane Cams and will make port around 7500rpm and make great torque combined with your gear and 4 speed transmission.
You will need good spring pressure, more than you have, My suggestion is 280 seat and 650 open
290/306 @.020"
260/268 @.050"
.670"/.625"
106 lobe seperation angle
Butch
By the way if you prefer Comp Cams, I would go with the following Comp Cams cam
Intake Lobe Number 2226
289 @.020"
260 @.050"
183 @.200"
.442" lobe lift
Exhaust Lobe Number 4264
301 @.020"
268 @.050"
182 @.200"
.432" lobe lift
Have the above camshaft ground on a 106 lobe seperation
By the way I did not post full specs on the Crane Camshaft above
290/306 @.020"
269/268 @.050"
184/183 @.200"
.670"/625" lift
Discussion Starter · #11 ·
Thank you but it is a CHEVY! lol
Discussion Starter · #12 ·
This is also in a street car! So I don't know if I want to go too crazy with spring pressure. When I plug the present cam spec. into Desk Top Dyno it seam too make the most HP with this cam?
Thank you all for you in put :)
i read an article in super chevy a couple months ago where they did a 302 build up with afr 210 eliminators,comp roller (640 621 256 260 @.050 107 lsa)procomp single plane,750 ultra hp holley.made 519 [email protected] 7400 and 400ft. lbs. of torque at 6000.
289 @.020"
260 @.050"
183 @.200"
.442" lobe lift
301 @.020"
268 @.050"
182 @.200"
.432" lobe lift
290/306 @.020"
269/268 @.050"
184/183 @.200"
.670"/625" lift
You and these HXL's.... it's a street motor and he needs the stuff to survive (springs, lifters)
The exhaust is a nice tame pick but that intake is not going to keep the deal cost effecitve in the long run.
Bret
Discussion Starter · #15 ·
This is the cam Bullet came up with.
Int-4032
Exh-4032
[email protected] 258/266
Lift with a 1.5 rocker 605/605
LSA 109
ICL 106
Discussion Starter · #18 ·
I don't want too change my shaft rockers. And the valve spring are done. So I figure why not change the cam if I have change the spring anyway. ;)
Butch
So what did you go with?
1 - 20 of 20 Posts
