1 - 8 of 8 Posts
When trying to open the files stored on my s d card I get an error that says this configuration file was created for hardware v300 serial#258.
You need a configuration file for this hardware v300 serial #9377.
Anyone know how to fix this? New install and first time using it. Thanks.
Have you installed the license disk?
it came with two discs. One for the data link software and one disk for the manuals. Should there be another one?
It's a USB flash drive. Black and silver, says v300sd license disk followed by the serial number.
Plug it into a USB port. Then go into the Racepak software, click security, read license disk. Check all 3 boxes and click ok. Select removable drive and click ok.
No matter which port I use they all say that they can't find the license disk. When I go through my computer and just try to open it I get a popup that says the disk has malfunctioned.
How old is the computer you are trying to use? If its a Windows 98 type machine I have seen this type of issue.
1 - 8 of 8 Posts
