21 - 24 of 24 Posts
Follow Chris's advice and use the Morels. Already spent the $$$ plus what Chris mentioned about ware and possible failure.
There are thousands of Morel lifters in use. Could you have gotten a fucked up set? Maybe. Or maybe the original lifters were fucked up? Best to measure from the furthest away part of the wheel to BOTH top of oilband and bottom of oilband and check with Morel on what those measurements should be. As for the oil hole being smaller? That could just be Morel engineering with oiling system for their product
Unbanned
sorry, i mixed up which lifter was which in the original pic.....................
Id run the Morel lifters too. As mentioned, they have a better band height and oil hole location than what you were running.
21 - 24 of 24 Posts
