At what hp level should you upgrade to the 3.812 9" case? And is the Moser bolt through case as good as the strange ultra case? I have 40 spline axles. Looking to upgrade soon
May it be exactly as strong but it's very close... You can do 40 spline in a 3.250 case with a steel spool... What kind of power do you have?At what hp level should you upgrade to the 3.812 9" case? And is the Moser bolt through case as good as the strange ultra case? I have 40 spline axles. Looking to upgrade soon
With Moser, the 3.250" and 3.812" bore case are the same price... It's also the same case with different bores within them.Its a 588bbc 1 kit on 275s. HP is around 15-1600 if I had to guess. Looks like the 3.812 case is not much more money over the 3.250. Just curious the hp rating on the 3.250
www.strangeeng.netSam, is the Moser comparable to the strange ultra case?
the Strange Ultra is the heaviest of the aluminum 3rd members, but without a doubt the strongest by far out of Strange HD, Moser, or Mark Williams. it is still 10-15 lbs. lighter than a Nodular iron unit.Anyone know the weight difference between the ultra case and the HD or Moser?
At what weight? That's more of the issue then your HP and size of carrier.I am putting 1800hp through a 3.25" Moser. No problem.
Strange told me the same thing. We are going with the 3.812 ultra case. Which fluid are you guys having good results with?I think the strength issue with the 40 spline axle and 3.25 case is the thickness of the area around the spool bearings. I like the Strange 3.812 ultra-case.
Strange will include Lucas gear oil with a center section. That's what I usedStrange told me the same thing. We are going with the 3.812 ultra case. Which fluid are you guys having good results with?
