1 - 1 of 1 Posts
T/S 368E
Doing a new front plate, 1/4" full plate.
The last time all I did was use the stock mounts and there was enough slop to use the stock mounts & stock tranny mount.
This time I want to know if I should tweak it a little, or it's not worth screwing around and just do it the same way??
So before I make the final fit, should I tweak the angle at all??
The mid plate & trans mount are NOT moving, so I probably can't get much, but is a degree or 2 worth anything on a 3000 lb ladder bar car???
Thanks Guys.
1 - 1 of 1 Posts
