does any one know how much i will save by cutitng them out is it wourth it or not thanks
Uh...Dont think so Tim! MUCH easier to cut a 2" x 6" hole on the end of the door and drill out spot welds and remove in one piece.The best way to do this job is to split the outer skin from the inner door frame, using either a spot weld cutter or a panel spreader. At that point the whole inside of the door is accessible, and the impact beam can be removed easily. Next step weld in new skins, paint ,and your done.
