1 - 20 of 287 Posts
April 19-21st will be here before we know it. That is the date for our second annual Shootout at the Springs. Who will be the first "official" run to the teens! It will come in April.
We will be running the following classes with purses noted!
Outlaw Drag Radial...............$5,000 to win!
X275...................................$5,000 to win!
Outlaw X..............................$5,000 to win!
Leaf Spring...........................$1,500 to win!
Mean Street.........................$1,500 to win !
6.0 heads up index...............$1,500 to win!
7.0 heads up index...............$1,500 to win!
FRIDAY April 19.......Early parking and Test N Tune
SATURDAY April 20 ..3 rounds Qualifying
SUNDAY April 21 ......Final Eliminations
Sponsors are coming on board daily we will have a flyer end of next week ready for mailing.
If you would like to become a sponsor please feel free to call 901-830-0179 Jabbo THANKS :p:p:p:p
Holly Springs Motorsports would like to say a big THANK YOU to Mitch at Certa Pro Painters for sponsoring the #1 qualifiers award for Outlaw X275 .
Any time you need interior,exterior whether commercial or residential the pros at CERTA PRO can hook you up!We at Holly Springs know first hand at the great job they do . The walls at the track are an example of the quality work they do .
Give them a call anywhere in the mid south 901-255-0514 :p:p
We would like to welcome X275 motorsports AND Salvato designs to our growing list of sponsors for the Shootout at the Springs.
John Sears and Jeff Salvato have stepped up to the plat and provided the #1 qualifier awards for BOTH the Outlaw Drag Radial AND X275 classes .
John is the "GODFATHER" of X275 and Jeff is Owner of Salvato Desigs. See Jeff for all your advertising needs, be it vinyl signs, t -shirts,flyers,and all your printing/designing needs . You may reach him at www.salvatodesigns.com or call 248-762-7388 Jeff has more than 10 years of experience providing enhanced customer service in a wide range of different industries including finance, marketing and drag racing media relations. Being involved in the world of drag racing has helped Jeff develop his skills of attention to detail, dedication and customer service. With these skills achieved, I significantly improved sponsor relations and helped propel myself to successful drag racing career. But after years of supporting these divisions, Jeff yearned for the one-on-one customer relationships that truly drive business. To this end, Jeff created Salvato Designs in 2010, a promotional based company devoted to providing personalized attention to detail to both screen printing and embroidery along with signs and promotional products to their arsenal.
THANKS JEFF AND JOHN!!!!!!
Jabbo :p
Thanks Jabbo! Always looking forward to making the drive to Holly Springs.
Discussion Starter #11
VP has jumped back on board to supply the "BITE" that only comes from the UU traction special blend. Pooch has been rounding up unicorns all winter and text me today and said "its ready" Holly Springs is the only track able to get this blend,THANKS Jason Ruckert!
Seriously THANKS to Jason and VP for the LC7 that has been proven with the "first to the 20's, first side by side 20's drag radial final, AND first "unofficial" run to the teens.
Vp is the leader in small tire traction compound thanks to all the work Jason puts in to it.
:D
Discussion Starter #14
here are leaf spring rules 68 ss
Single power adder only except 4cylinder or V-6
SB NA................................................ ........................ ............ 2500 lbs
SB N20 single kit .................................................. ....... 2750 lbs
add 50 for muti-stages
add 100 pounds for canted/splayed/sub 14*
add 25 for extra carb
SB Single turbo/blower................................ ............ ............. 3300 lbs
add 75 for f3A
SB Twins/blower.................................... ................................3375 lbs
BB NA (Up to 640 c.i.)............................................. ................3000 lbs
BB NA (Over 640 c.i.)............................................. .................3100 lbs
((((BB nos 2 stage limit 24* & greater valve angle .............................................3250 lbs
add ((((50)))) pounds for less than 24* valve angle )))
BB Turbo/Blower........................ ..........................................3450lbs
add 50 for f3R 130-139/vortech v28-123 (110mm reducer required)
BB Twin turbo/blower................................... ........................3500 lbs
Inline 6 Cyl (Turbo/N2o Combos)........................................... ..-500 lbs
(Deduct from SB blower turbo Weights)
4 Cyl/Rotary (Turbo/N2o Combos)...........................................-800 lbs
(Deduct from blower turbo Weights)
**Inline 6 & 4 Cylinder Boosted Combos are allowed 1 single N2o Nozzle between Turbo/Blower and Intake**
Turbo limits:
SB turbo 101mm max. Reducer ok
SB twins. 76mm max. Reducers ok (88mm original inducer diameter max)
BB single 101mm max reducer ok
BB twin. 80mm max reducers ok (91mm original inducer diameter max)
Reducers will be measured 1 inch from impeller and must attach to the compressor housing. All air entering the turbo/blower must pass through the specified bore diameter.
No 5.0+BS big blocks
640 max cubic inch N2O
588 max cubic inch boost
CHASSIS/SUSPENSION:
1.)Leaf Spring Only Suspension!!! No rear coil overs or other coil springs, no ladder bar floaters
2.) No full chassis car
3.)Can move leafs in and shocks can be in any location.
4.) Frame Notch permitted.
BODY/INTERIOR:
Anything goes as long as at weight, no tube chassis back half cars. Stock Appearing interior.
MUFFLERS REQUIRED!!! (Except Turbo Entries).
No wheelie bars!!!
Max 275/60 drag radial or 28x10.5 non w slick Sidewall
thanks look forward to seeing you .!!!:p
Glad to see Mean Street on the ticket!!
See y'all there!
What are the rules for OUTLAW275
1 - 20 of 287 Posts
