Right now I run the W on a 12" wheel and was curious the growth of the S vs. the W? The W's rub just a touch and I know the S's are a little taller but wasn't sure if they grew as much as the W's do.
They both have a stiff sidewall and will grow about the same. Depending on wear you are rubbing, you may have less trouble going to the "non W" tire just because it is narrower .
I don't think narrower will help. It's rubbing at about the 2:00 position on the quarter panel in my sig pic. That's why I was curious about the growth. Oh well, I'll stick with the W's. Just thought there may be a little better option. I also have 12" wheels so that stretches them out a bit.
