1 - 15 of 15 Posts
Discussion Starter #7 (Edited)
Re: 29” Drag radial
kinda splitting hairs.....
Kinda? The 295/65 is like 30.25, That's pretty big for my car's fender, A 60 series would be better, but they don't make them, I don't know how good the hoosier drag radials are? I've only ran the Mt's
I'll prob just stick with the 275, don't like the look of a 295/65 on my car
Re: 29” Drag radial
its a diff of .750 witch is really .375 taller and .125 wider per side....tryin to help not bashing.
Re: 29” Drag radial
SBP , the difference can be enough to fit or not fit .
With the mt 295/65 et ss tyre rolled into dogleg through/after finish traps . I moved diff back 1/4"to fit the PBR 29.5x10.5 .
I did buy and try the Hoosier last Friday night . A lot more room . The main difference with these , apart from being 29.5 tall , is I am using a lot more tyre psi . Was up to 22psi from 19 1/4 . After seeing pics I may be able to go to 23 , was still a lot of sidewall wrinkle . hey also have a squarer shoulder .
Tex
Discussion Starter #11
Re: 29” Drag radial
I get what your saying, but the previous owner tried the 295/65 when he owned it and it caught the drivers rear quarter turning onto return road putting a crease in quarter. I would rather not do that again lol
Re: 29” Drag radial
lol...it is a big tire!
Do you make a 27inch tall 9 inch wide drag radial.?? Just used at the strip
Mickey Thompson ET Street S/S 255/60-15 tire is 27.28" tall and 8.82" tread width and the Mickey Thompson ET Street R Radial 255/60-15 is 27.52" tall and 8.82" tread width
1 - 15 of 15 Posts
