1 - 3 of 3 Posts
Fox body, cut through the floor frame connectors.
Do I require the X bracing underneith the floor?
Floors are completely welded to the frame connectors.
Has the rules for 25.5 changed in the last 2 years?
no x bracing on the 25.5. on the 25.2 yes. The 25.5 you do need a "but bar" on the drivers side between the 1 bar and the 6 bar that runs from your drivers side rocker to your inner frame rail.
1 - 3 of 3 Posts
