1 - 8 of 8 Posts
with the 2b bars, do they have to connect to the main crossover(bar 1) or can they be ran from the lower horizontal cage support(bar 15)? i've seen a couple chassis shops run them from the 15 bar but in the pics it shows them coming from the rear cross member. anyone have the right answer? thanks, mike
Discussion Starter #2
nobody?
update for anyone that cares: 2b bar MUST connect to bar 1 as seen on pages 21 and 22.
if your car still has the stock susp,mini tubbed with steel and welded in and all factory floor. There not required,so You sholud be fine.
Discussion Starter #8
im putting full tubs in it and the rear trunk has been cut out. no biggie for me.
1 - 8 of 8 Posts
