1 - 7 of 7 Posts
25.2/25.3 10.5 68 camaro worth? it has both stickers on it brand new car! car has full tube chassis from the firewall back
glass tek front end
glass tek 6'' cowl hood
glass tek doors
glass tek trunk
five stars windows
16 x 16 beadlock 10.5w
Aluma Star V 2.0 weld one peice front rims
autofab front arms
9'' fab rear 40 spines axles 389 pro gear
stroupe belts,net,parachute
88'' pro bars
rear alum wing
setup for turbo sbc with glide
has motor plate and mid plate from rick jones
just asking bc drag radial is the new hot thing going on now
has this car been run? does it have fuel system and wiring?
i get pic up soon im looking to get around $25k or so, so good when im ready to sell it ill post it thanks!
ls1 s/s notch on 28s
it would be cheaper to just get you some frame rails,cut the outer bars out and put the frame rails in and tie that all in and then put in stock mounting points for the leafs and bam you have a stock suspension radial car..
1 - 7 of 7 Posts
