1 - 4 of 4 Posts
Anyone ever have to mount the steering rack under the frame rails on a 25.1 e car? I have a car in here and the frame is to high in the car. Its not at the bottom of the rockers, its at the top.
can you think of a reason not to mount it under the frame rails?
Its going to depend on how the front suspension is installed. If the rack is too low you will put bump steer in. Seems if the frame was raised that much your ground clearance will be really a problem.
Maybe some pics or more info.
Corey
Mine is under the frame rails. It is mounted to a wide U bent tube and is copied off a old Alston kit. Run low 5s at 135 and not a problem and it has zero bump steer.
1 - 4 of 4 Posts
