1 - 3 of 3 Posts
do you think that a tunnel ram intake is worth the extra $$$$$$$'sssssss and effort ? what size of carbs ? I want to mainly run on motor but i will also have a fogger plumbed to it ! here is a lil about my combo it is a 377 14.5-1 2.10 * 1.625 dart race series 220 heads comp cams solid roller .730 i 704 e 284 i 296e @.050 113 icl installed @ 112.5 how much horse power could you see gaining ? who's intake should I use ? the engine would look bad ass with 2 750 cfm dominators on it but i think taht would be a bit too much . any help would be appreciated thanks Glenn Kotas
Chris Uratchko said:
That's a TON of camshaft for n/a... how heavy is the car?
3250lbs I was going to use this for a plate system but There is no use in spraying it i'll just break parts and it wouldnt be fast enough to keep up with the big dogs anyways . Glenn
1 - 3 of 3 Posts
