1 - 7 of 7 Posts
Hey I am sorry if this has been asked before, I have searched on here a great deal and found tons of info on the famous 245 ap heads but not as much on the smaller 227 heads. I have a set of these with the 2.150 valves. My question is what is the power potential with these, na, of course? And what size engine are these best suited for. I have always had good luck with conventional 406 setup, but I am going to buy a dart block now and will I be ahead to go 421. This is going to be heavy nitrous application sometimes. Thanks again, Josh
EFI/N2O JUNKIE
They will work better with a larger bore, like a 4.155 or bigger. I am running mine on only a 4.130 bore, didn't know better at the time.......
And those RR227 heads are where the RR245's come-from. You aren't talking about their AP220's are you?
They are for sure raised runner and say 227 on them. I hear they are the same casting as the 245s but my budget can't handle the cnc upgrade right now. Thanks for the help!
Also what power potential am I looking at? I have not flowed these but they should be in the low 340 range I would think. Basically what I want to hear is, on a 13:1 406-421 with proper solid roller will they make 725 or is my figuring wrong?
EFI/N2O JUNKIE
You should be close with the correct intake. I am only running a 2.125 valve on a 4.130 bore, 3.875" stroke, 13.5:1. I have to assume that either someone ported these heads or they were bought with one of Bob's programs run on them already. Obviously the RR245 program wasn't done to them.
Discussion Starter #7
What kind of times are people getting out of these? I am have to weigh 3150 on a 275 limited to an .082 nos jet. What is a realistic e.t. to expect in the 1/8? I am shooting for 5.6x's
1 - 7 of 7 Posts
