Posted by tasca on fb
Just Announced... New Ford Racing Crate engines/control packs
Ford Performance Coyote Crate Engines – Transition to the 2015 Coyote
The transition to the 2015 5.0L Coyote crate engines has begun. For you and your customer this is expected to be seamless as there is very little difference between the current 2011-14 and new 2015 engine and control pack.
WD Information – Standard 5.0L Coyote
• The part number for the 2015 Mustang GT 5.0L engine is M-6007-M50A and is available for order and will ship immediately
o Note the suffix “A” has been added to denote the 2015 engine
• The part number for the Control Pack is M-6017-504V. This Control Pack must be used with the 2015 engine – the 2011-14 Control Pack will not work.
WD Information – 5.0L Aluminator Coyote
• The Aluminator Coyotes – M-6007-A50NA and A50SC - will also transition to the new 2015 Coyote engine and will follow the same build content and modifications as the 2011-14 engines.
• The parts numbers for the Aluminator 2015 Coyote based Crate Engines are:
o M-6007-A50NAA – In stock and available for shipping
o M-6007-A50SCA – In production and available for ordering
• The part number for the Control Pack is M-6017-504V and must be used with the 2015 based Aluminators.
• The Aluminator short blocks will also transition to the 2015 based Coyote as well. The 2011-14 based short blocks are still in stock with production of the 2015 based engines planned for October. The part numbers for the 2015 based Aluminator short blocks are:
o M-6009-A50NAA
o M-6009-A50SCA
• The content of the 2015 based Aluminator XS (M-6007-A50XS) is in the process of being finalized and will communicated in about 30 days.
Customer Information - The New 2015 Engine
• The 2015 5.0L Coyote engine has several changes that improve the power output to 435 horsepower
o New cylinder heads that flow more air
o Charge Valve intake manifold that improves low speed performance
o Larger camshafts
• With the changes to the new Coyote, some of the 2015 engine components will not interchange with the 2011-2014 engines. Contact the Ford performance Tech Line for specific questions. A summary of the compatibility between the 2011-14 engines and the new 2015 engine will be posted on the Ford Performance web site within the next several weeks.
• Note that the Coyote engine as installed in the 2015 Mustang uses an exhaust manifold with an integrated catalytic convertor on the left side. Due to its cost, this manifold this is not included and the engine is shipped only with the right hand exhaust manifold. This “right side only manifold” information is called out in the product information for the engine.
2011-14 5.0L Coyote Engine Control Pack
• Note that the engine control packs for the 2015 and 2011-14 engines are not interchangeable. The 2015 Coyote has moved to a new level of engine control hardware and software that is more sophisticated than the 2011-14 Control Pack.
• The control pack for the 2011-2014 5.0L engine will also transition to the new PN - M-6017-A504VA that includes the Speed Dial Wiring.
• Speed Dial Wiring improves the engine idle quality on deceleration.
• This control pack will continue to be available indefinitely to service customers who are pulling engines out of used cars.
o M-6009-A50NAA
o M-6009-A50SCA
o Larger camshafts
